1 - 9 of 9 Posts
Guys,
I have a 2019 F-350 KR 6.7. Its my baby, it only goes out on sunny days. Anyway, I have owned it for a year, DIC says to change the oil BUT I don't even have 1k miles on it yet. I thought I read somewhere that Ford put "break in oil" in the Superdutys and not to change until you reach 5k miles for first change.
FYI- I don't idle or tow or anything severe basically boils down to being my Sunday driver..
Thanks in advance for the input...
You have a engine warranty to protect, if the DIC says to change the oil then change the oil.
Also my best recommendation for you is to drive your truck, these new engines were not designed to just sit in a garage
Change it, drive it. Now you're going to get nervous when you don't see the DIC to tell you to change the oil when your at 5k.....7k.....8k......9k.......
in some cases. It's 10k spend the money and run 100% synthetic and enjoy your extended oil changes. As expensive as it is now? You'll be glad you did. My Truck sees 30k miles a year and on average it tells me to change at around 9,500 miles. But always keep track of your mileage for reference. Use trip meter one specifically for mileage. Use trip 2 for whatever.
Sent from my SM-N960U using Tapatalk
They don't put brake in oil in these trucks. I didn't change my oil till the truck said i needed to do that. I got mine new not used. You are lucky that you can put yours in a garage. I don't get to do that LOL.
I do believe that the oil minder in the truck will have you change the oil every 5 to 7,000 miles or once a year which ever comes first. Sorry to see you don't drive your truck much. When I got mine I had to put the 5th wheel hitch in mine so with around 500 miles I have to cut a 4" hole in the bed. How brave of me. Thank God I can read a tape measure. There are no do overs once you have the hole cut. Get your truck out there and drive it man.
Drive the truck more often. Letting them sit isn't going to do anything to add value. Change the oil to whatever you want to use. Synthetic oil usage isn't a automatic for "extended oil change intervals".
Read the manual closer, Change oil at 5,000 OR 1 Year. The oil minder counts miles and time, so will notify either way. Sitting is very bad, especially in the upper midwest where there is snow, freezing temps, and high humidity with varying dew points. All these lead to rust forming, and water condensation. Killed my 99 Dually by letting it sit, even though it was garage kept, it still got damaged from rust.
I don't drive mine much either and am in the same boat. Trucks wants me to change the oil, but it has less than 2k miles on this oil. I do need to drive it around a bit more. Usually when I do it's towing 7k. Mine was 3yrs old in Dec. and I've got just a tad over 12k.
I need to change it soon tho. Just hate waiting on the dealer all day to get it done.
Mine will be 3 years old on Feb 28th and has 87k on it now.
If I only logged 1,000 miles a year, then I would not bother using full synthetic unless I used it in a very cold climate.
1 - 9 of 9 Posts
