The resistor is mounted on the side of the blower housing under the hood. If it was the resistor, you should have high speed. More likely, your fan motor is bad or a fuse / relay. You can check this with a voltmeter. I attached a .pdf showing the resistor:
For a ******* test, run a 12 volt jumper wire over to your blower motor.
