The Truck will just barely run at all and I just replaced the IPR and the ICP and it was running better before I did this. Just learned ICP voltage is supposed to be .24......PlUS I'm getting zero codes from my ScanGauge2.
A wiring harness is $630 and I don't have a clue if it will even fix it.
Question?
Does the power wire to the ICP run all the way thru the harness?
Is it possible for me to pull the harness off, inspect for chaffing and if I see chafing is it even remotely possible to trace the wire back after completely unwrapping the harness and then somehow get it all back together?
I'm about to pull my hair out over this damn truck.
Question?
