I have a 2000 F250 2wd. 187000 miles with not too many problems. 4 weeks ago, my temp. went to red so I pulled over and let it cool. Had to add about 2 galons of water to get it going. Took it in the next day and they did a flush, pressure test and changed the thermostat... all's well. Ran great for the next 24 hours. Folling day, I had to head up to Tahoe (long steep grade)and same thing happens (engines over heats). I pull over and had to add 1 gallon of water to get me going as well at turn on the heater to help with the temp, (keep in mind the tempeture is 40* outside so it's not a hot day). I drive aroud town with no problems for a few hours and then head for home. Up the grade, same thing happens and I pull over and have to add 3 more gallons of water with no signs of leaks. Take it to the shop next day and they do another pressure test and flush the engine again. Truck runs great for the next 2 weeks with no problems till the next time I go to Tahoe. Same grade, same thing except this time by keeping the heater on, the tempeture goes down to a safe level. Heater in not needed at any other times. This time, the engine start to heat up in town on flat freeway while the A/C is on, so I turn on the heater and temp. goes down. My mechanic is a good friend and 1st susspected the fan clutch. After a couple of thourough checks, he's not sure what it is but want to probe deeper by pulling things apart to diagnose (he does this for free so $ gowging is not an issue).
He feels the truck has a huge loss of power and should be more responsive and powerful. He thinks there's something wrong with the turbo. I've had the truck so long and it's run pretty much the same that it feels normal to me. There is some history behind his assumptions as I had issues with the truck while it was still under warrenty (around 30,000 miles)from repair from the dealership. Any help is appreciated and if the prior problems would help the diagnosis, let me know and I'll post them. Thanks in advance.
