1 - 8 of 8 Posts
I started the truck yesterday to move it, and before it was really warmed up (granted, it was like 55 degrees out), I tried to drive it up a slight incline.
The motor kind of loped, then the Overdrive Off light started to flash.
I parked the truck, and restarted it, and the Overdrive Off light was NOT flashing.
Any ideas?
My CEL bulb is burned out, so I don't even know if I have a code.
Opening the dash this week to change out the bulbs.
My idea would be to read the codes. When the OD light flashes it stores codes in the computer. The codes will stay there until manually cleared, or approximately one month, whichever comes first. The places that read codes free CANNOT read these codes. You need either a Forscan setup (less than $30,) or a good independent shop, or a Ford dealer to read the codes.
Autozone pulled a p1247 code. Turbo related.
You should have read this:
That code did not flash the OD OFF light. The code that did is still in memory. We won't know what needs attention without that code.
I had my mechanic pull the code, and it is the turbo code.
He cleared it yesterday, hopefully it doesn't come back.
I'm makeing 15 lbs of boost pulling my loaded 2 place snowmobile trailer up hill at 60 mph, so hopefully it was just an errant code from trying to force the truck to move uphill before she warmed up.
Once again, that code did not flash the OD OFF light. The code that did is still in memory. We won't know what needs attention without that code.
Discussion Starter #7
The only code that he saw was the turbo code.
Do you think his scanner wasn't capable of seeing the OD flashing code?
I'll look into the ForScan tool.
I know his scanner wasn't capable of reading transmission codes. Turbo codes do not make the OD light flash. Only transmission codes can do that.
1 - 8 of 8 Posts
