The display gradually got dimmer over the last year or so and just went completely out. This is the display for temp, mileage, compass heading and miles to go.
The dimmer switch used to affect the brightness even as it gradually got dimmer until now as I have no lights at all.
Can't be a fuse as the manual shows the same fuse runs several other things that still work, and can't be a bad wire as it was a gradual weakening.
Anyone have an idea what is wrong? Also how do you remove the console cover? I see the two latches inside the compartment but can't see how to release them.
