The truck is a 1995 ps 7.3 no tuner no chips only electric fuel systemWe need more information! Year of truck, year of engine (if different), and modifications such as tuner, chip, etc. Here are some pinpoint tests for P1211. Cheers!
Yes everything is motor craftAlso. Are you using TRUE Motorcraft sensors from a trusted source?
truck starts fine now.. after a few secs the cel light comes on then the idle goes up and it has a miss…. By any chance you ever seen or heard of the return lines from the hpop collapsing ?If using an 02 HPOP on a 95, you will have reservoir oil drainback issues causing the long hard starts. You also may have air in the system after pump changeouts causing extended cranking until air gets worked out. Also, make sure you have the correct HPOP gasket for a 95. Cheers!
Does the CEL come on when it does this? All the oil used in the HP Oil system returns back to the oil pan (there are no return hoses). The hoses connected to the HPOP are supply hoses under pressure. Cheers!
[/QUOTEyes the cel does
So when installing the 02 hpop what gasket should i use 95 or 02
