2012 F550, have an active fault for heater circuit A fault. Removed the DEF tank, checked the heater in the tank, its reading 195 ohms. Tested heater relay prior to removing the DEF tank. Relay tested good. Any suggestions,
I can't locate a system schematic.
Had the same fault. Had the truck in for the 14E03 recall and my work ticket says the PCM reprogram cleared the code. It has not returned.
Sensitivity issue and a new PCM load fixed it?
Does the 550 fall under the emissions recall?
