On my truck, my parking brake has never really worked great. When I had my brakes replaced, they said the parking brake was fine. I noticed there is no adjusment on the cable like a bike brake, do I need a new cable, or is there something to adjust inside of the hub?
The parking brake is a drum brake inside the rotor, if you look on the inside of the rear wheel, you will see a rubber plug right by the axle housing, remove it and there is a star wheel, turn that to adjust. Jack up vehicle, adjust until you can feel drag, back off until no drag. Repeat on other wheel.
where did you get your cable.mine just broke
