Finally getting around to wiring up my Rigid LEDs. (one set 4" driving and one set 4" fog) Found the blunt cut wires under dash that have colors that match up to what book says they should be. Also found blunt cuts in engine compartment where they should be but the colors do not match book. Does anyone know which wires go to which switch? Colors are white, brown w/ white trace, white w/ orange trace, grey w/ red trace. Any help will be greatly appreciated!
Discussion Starter · #2 ·
OK, may have found an answer. Would these be some of those wires that are not connected to anything on either end? Found matching wires under dash taped to massive wire bundle. If indeed these are the same wires then can I just connect the end under the dash to the wires coming from the upfitter switches and the other end to the lights?
