In a bit of a pickle. I thought the plastic frame around the fan would be somewhat flexible. Sadly I can't bend it out of the way to get the fuel line bracket around the mouth of the intake manifold. Took the bolts out, but the plastic is too stiff. I tried searching for a solution already but it seems like everyone just cuts the line when removing it. Not an issue for me except that I need to put a new line in it's place and I intended on putting the new line in the same way I took the old line out.
Backstory is the old line is somewhat bent out of shape and the top nut is twisted/warped. As such it doesn't put enough pressure on the connection to form a proper seal.
