are you sure the yoke nut isn't loose? that can be a start when you take your drive sahft off. if its loose tighten it back up and drive it til you see it leak. i have alwasy used just regular 90w oil..... Gibson
Make sure you check the area the seal rides on so that the shaft hasn't worn. You should be okay but you can put a wear sleeve in if the surface is bad.
Greg
