Was driving and came to a stop sign and I had nothing going to the wheels. No burnt tranny fluid, No noise, no prior slippage, all plugs are in, no dtc codes.... nothing. When put into gear it does nothing but rev up when pedal is applied.i. at a loss... Im assuming it may be a shift solenoid , pressure pump or lets hope its not the tcm. Any ideas?
Could also be a broken input or output shaft. No matter what - the transmission has to come out.
It isn't the TCM. That cannot cause this. In fact, there is nothing electronic that can cause this. It is something mechanical.
Is it a 4x4? If so, does park hold, or will the truck roll when in park?
