Hi I have a 05 f350 with the 6.0 Powerstroke never had problems out of it till other day I backed it out of drive way to presher wash driveway and when I went to move it no power so I’ve replaced the pit valve the icp sensor and also did a blue spring kit still nothing it starts but very hard and will idle some mostly rough but stalls out in gear no codes no nothing doesn’t white smoke either just a hell of a lot of black smoke???
Black smoke at idle, no power, stalling - assuming your truck still has one, check your EGR valve. It can stick open and not set a code depending on the position sensor voltage when it does. It does not take much to choke an idling engine and cause the symptoms you have. When this occurs the engine will sound quieter than normal.
