Did you see if the oil pattens from the injectors on both banks are the same now? Have you tried unplugging other sensors? They all share a reference voltage so if any one of them are acting up, they can drag the others down. The EBP is the usual culprit, but MAP, oil temp, air temp all can be faulty. Change the CPS to your original if you can.
