Had my 3rd flywheel failure at 96K and waited until my 4R100 acted up before adressing it (luckily got both covered under Geico warranty). Anyone else have a flywheel failure? How many miles?
Symptom was the loud rattling sound at idle or when off accelerator pedal (sounds like a chunck of sheet metal is loosely bolted to engine block, gets lots of attention from anyone in earshot). I have the last 2 flywheels and both sheared right around the crank mouting bolts in a circular fashion. Since the failures have been so simlar, I am wondering if others have had this problem (or did they revise the flywheel in 2000) or if I have a 'hot' starter?
Also want to hear about any aftermarket options since I'll be out of warranty soon and need to plan ahead, assuming this trend will continue.
THANKS AS ALWAYS FOR YOUR INSIGHT!!!
Ty
Ty
