1 - 18 of 18 Posts
I like hybrids. Easy on the oil and great fuel flow...
i'm game for the stroke AA codes, with dual oil pumps that is. of course i'm biased /ubbthreads/images/graemlins/biggrin.gif /ubbthreads/images/graemlins/smokin.gif
I'm with Jim. But you already know that /ubbthreads/images/graemlins/biggrin.gif
Super MM's with 12 thousandths tips and a Terminator setup is pretty mean and proven.
Regular MM's are hard to beat on a single HPOP.
Just out of curiosity, how much power has been made on Stroked AA's with and with out big oil?
Discussion Starter #6
I'm curious too.
Has anyone ever tried anything in the 200cc range AA with or w/o oil?
Currently with my 2's I have no issues AT ALL with oil. Just seems to me that you could go a bit further. but I'm no IDE so who knows.
I don't want to reinvent the wheel, and I'm sure alot of different combos have been tried and tested. Some may work better than others. Seems that there are alot of ways to skin a cat. I'm generally cheap and like to get the best bang for the buck at the same time I like to do things once and not take baby steps every year.
David, have you ever tried a 12 thousandths tip on a regular mm.
Yes, went [email protected]19 on Nos and [email protected] on #2only stock HPOP
A lott of bang for the buck.
Yes, went [email protected] on Nos and [email protected] on #2only stock HPOP
What Turbo? I am looking to upgrade my GTP38R.
GT42R, that same combo should be good for another 50-60rwhp over what it ran then.
I need a bigger turbo Lott. /ubbthreads/images/graemlins/phoney.gif
We dynoed a set of a codes at my open house that did 511.
We have made a set of 200's for soemone and it runs mid 13's on fuel but he has Stealths. 200's wont work on a single, 180 max if you have a really good pump.
Like Lott said, hybrids a cheaper way to get the fuel on a single pump.
Hopefully I will get my truck to the track either this weekend or next weekend to see what it will do with the new turbo. Hopping for low 13's with the stock oil pump. Was going high 13's with the stock turbo and still had a lot of fuel left in it that the stock turbo couldn't clear and it wasn't setting an oil code either. Mine are A codes last time I talked to hypermax Ron told me that they were around 190 cc
[quote
When I data logged my last run on Dunbar's Dyno we ran 2100psi at 1/4 throttle and ran 446hp on fuel only with the "AA codes" thenn popped a boot at around 60psi boost.
1 - 18 of 18 Posts
