I just picked up a 99 f250. It just had injector #7 replaced and wiring harness on that side. It has the superchip program installed. It ran great for a few days. I drove it about 300 miles then it sat for two days. When I cranked it up to let it warm up it did a wierd thing. It increases rpms on its own. I depressed the pedal and got no response at all. I turned it off, turned it back on and good to go. Driving off the ranch I stop to say bye to some one and it increases again. I depress the brake pedal and rpm returns to normal. No issues for 300 mile trip, then stays parked for three days. On 200 mile trip running rough in performance mode. Diesel fumes worse than normal. When I get home i retune to stock settings. Idles perfect. I depress accelerator pedal and it lugs with lots of smoke. Nothing else. Retuned to performance mode and it idles better(drivable) but not good. The only codes i could get were p0603, p0222, p0381. I only got them once. Cleared mutiple times, retuned multiple times. Could not get same codes sitting in driveway. I am not sure if this is a tuning issue or something else.
Any Ideas?
sTw
Any Ideas?
sTw
