A 6.2 with 4.30 gears is a nice replacement for a 7.3 with 3.73 gears. While it is not a diesel, it does pull well, with the 4.30 gears is rated to pull up to 15,000 and has cheap and easy maintenance. You will more than likely have to order one to get 4.30 gears because most dealers don't order them, there are some out there, if you don't mind the drive.
