Passenger door power lock stops working - kind of. It would lock but not unlock. Wasn't sure if it was the motor, or wiring.
Came on here to find any info that might help before I pull the door apart. Found some guys talking about the small resistor? (I think) and ptting tinfoil in it to bridge.
Anyways, pulled the kickpanel off to check the wiring first and pulled the wiring plugs apart and realized one wire was corroded right off inside the female plug.
Spliced the wire together from the plug with a quick connect and the lock works fine now.
Now I just have to lube the mech. so I can use the key again.
Hope this helps someone else out.
