1 - 8 of 8 Posts
Howdy
I have a 2000 psd, 2wd. Starts and idles fine. But I am experiencing loss of power trying to accelerate. At highway speed I floor it and it seems to be lugging down quite a bit. I changed the air filter and will do the fuel filter tomorrow when it warms up. Any other thoughts?
Eric
2000 psd, 122,000 miles
Check for loose boots on the IC tubes, leaking up pipes, or possibly a damaged MAP hose.
is it really cold there? its got down to say low 30s here, mine dose the same till it warms up. then all fine. its been doinn it since new almost. i really feel it goinn up a steep hill by my house, i try pluginn it in when its cold. it dont happen as much then.
That's your EPBV closing to aid in engine warm up. It also increases the turbo noise and give you that jet engine sound.
A bad thermostat will keep the EBPV closed, causing a lack of power and poor fuel economy. However, it should cut out on hard acceleration and allow normal power. I would check fuel pressure first. Then maybe look for a turbo boost leak.
It's not the warming up thing, I've had the truck for almost 9 years and know about that.
I changed the fuel filter, no change. I'm pretty sure the turbo is working, how can I be sure?
No idiot light on but is there a sensor that could be gone?
I can't check the fuel pressure, but I might have to take her to the hospital anyway.
Eric
It might be better to have someone diagnose it properly. I doubt if your fuel pump is bad. You would really have to look at the fuel pressure. If you replace it and it does not fix it you are going to be in the same boat.
1 - 8 of 8 Posts
