Did a power steering flush and think I may of got some air in line. The reservoir is a lot smaller vol wise than I thought a few turns and a pump and its low. I drove it around and no noise so will it bleed itself or do I have to do something? Assuming symptom is noise are hard to turn not sure sine it's a hydro boost will it cause brake issues
The easiest and fastest way is to jack up the whole front end to the point that both front wheels are off the ground. Then start the truck and turn the steering wheel back and forth from left to right or right to left which ever way you prefer a number of times.
I put 4 qrts thru system and the mess only took half the time of the bleed. Thanks for air bubble advice
