i had my PS go this weekend, all of the fluid leaked out as fast as i poured it in???? looked under the van and looks like the high pressure fitting on the PS is leaking???? anyone ever have this go bad? and what to replace??
You need to find out exactly what is leaking. Might have to clean it off a bit and watch where the fluid is pouring out. It is usually just the pressure hose from the pump to the steering box. If so then it is just replace the hose. Can also be the pump leaking at the shaft seal, but not very common. Pump is also easy to replace.
You need to find out exactly what is leaking. Might have to clean it off a bit and watch where the fluid is pouring out. It is usually just the pressure hose from the pump to the steering box. If so then it is just replace the hose. Can also be the pump leaking at the shaft seal, but not very common. Pump is also easy to replace.[/QUOTE
where can i find a service manual?
Thanks for the replys. I replaced the high pressure PS hose. So far So good!
