I have a 2002 F350. I have changed the power steering pump 3 diff times now and none of them seem to be curing the problem.
The original went out and i used a Napa reman,Also changed the gear box at this time, didn't last long so i changed it with a new Ford one, It went a year and seemed to be getting weak, wouldn't turn unless reved up etc. Changed it with a new Napa it works fine but has a terrible howl to it. I flushed everything all of the times i have changed the pumps. This one i have done twice thinking maybe the ATF wasn't the way to go so i used ps fluid , but still annoying howl. The other reason for changing the Ford pump was hearing, to quote another thread, " a mashed cat sound" no rime or reason to it comes and goes as it like cold hot 4x4 and 2x4? Is there something in the brake boost system i am not looking for, maybe even in the steering ?​
You need to check for seized ball joints or axle u-joints as seized joints will put a lot of strain on the pump when steering.
I had the same trouble with pumps...replaced it once a year and the new one always howled! I found out that most pumps are made by A1cardone and they are junk!! bought my new one from Ford and put Schaffer trans fluid in it and am on 3 yrs now without so much as a squeek!!
This exact thing happened to me after they repaired the right side ball joints and u-joints. The dealer said there must be air trapped inside the system so they put the power steering system under a vacuum while they turned the steering wheel from lock to lock about a dozen times. I know it sounds strange but I watched them do it and the power steering pump is nice and quite now.
never heard of vaccing the power steering but if it works, cool
Has anyone changed over to the saginaw pump, if so is it worth the modifing? Thanks
