I've searched on here but I cant find anyone with the same issue as me so I need some help. While turning (left and right) into a curve sometimes I can feel resistance on the wheel, if I hold slight pressure on the wheel (to continue thru the curve) the truck will suddenly jerk the same way I am turning the wheel. Here is the kicker it doesn't do it all the time but is getting more frequent. I have checked for a possible binding front u-joint,tie-rod ends,ball joints,pitman arm joints and hub bearings all are ok. The power steering pump seems ok ,no whining noise, no leaks from any hoses. Need help it's kinda dangerous in a curve on a wet road and the front end tries to jerk around.
