It's starting to growl. Does this mean I should be looking for a new one? Any have a good source? Thanks WRP /ubbthreads/images/graemlins/smokin.gif
I'd check your fluid to be sure if it's got plenty of fluid and it's growling then you're in short order to replace, if it's just whining then that's just b/c it's a ford pump
Banned
I've had then start growing before and they were low on fluid. Once I topped it up the growl went away. If that's not the case then you may end up needing a new one before long. Make sure the fluid is up before you run right out and buy one though.
Discussion Starter #4
I'll double check on it /ubbthreads/images/graemlins/cool.gif WRP /ubbthreads/images/graemlins/smokin.gif
