Not sure if this is the right place to ask a question or not,but here goes...'97PS,212,000miles, never had a problem with truck.Have alway kept oil and filters changed(Dello400) Started getting a little hard to crank (start)first time in the mornings about 10,000 miles ago,I live in Texas and our winters are pretty mild.Noticed I was losing a little power and truck sounded like it had a solid miss at idle.Had local mechanic check it out and problems seemed to point to #2 injector.I pulled all injectors on drivers side bank of engine and replaced #2 injector with new Allied injector. At the same time I cleaned tips of the other three inj.with 00 steelwool and carb cleaner.Also I replaced all o rings on the 3 injectors I cleaned of course.Truck started right up and sounded good and smooth.Also I should mention that before doing described work the truck would run smooth and strong until fluids would come up to operating temps,then the miss and loss of power would show up.(oil pressure remains good according to gauge)
O K back to truck after repairs. I changed oil and filter as well as the fuel filter and truck performed as new for maybe 600-800 miles.Then one day at lunch I stepped out of truck and noticed slight smoke coming out of exhaust at idle and a pretty strong smell of burning rich.I returned to work about 5 miles away and noticed same symptoms but was not alarmed.On the way home from work later that evening when I was about 1/4 to 1/2 mile from home something let go and it started to smoke like you wouldn't believe! Engine was clattering like noise when first started on a cold morning.Engine ran for no more than 30 seconds total after this occured.Have not attempted to start it since.Took top of fuel filter canister off to check for contamination and don't believe the cannister was full,if that means anything or not.
Well there you have it,and again I,m not sure if this is the right place to ask questions or not but hope it is!
Any help or thoughts on this matter is greatly appreciated!
Could it be an injector was not seated in the bore good and has become loose?
