Afet staring at this thing in my tool box for three years I decided to actually hook it up. Ran into drama at the splice into the black connector at the bottom of the brake master cylinder. Which of the three choices of wires did you splice into??
I've got a green with yellow stripe, brown with green stripe & a solid black. Supposed to show twelve volts with the key in the run position.
I could only get two of the three to show 4 volts with my cheesey circuit tester. Although it would show 12 volts at the battery itself. WTH??
Which of the three was yor choice, my truck is an '02 f350 sixspeed.
Thanks,
Cris
Thanks,
Cris
