1 - 15 of 15 Posts
My 02 Ford F350 7.3 L Powerstroke is starting to build up too much pressure in the radiator. My clutch fan went out and started to overheat the truck while Towing. Now the upper radiator hose blew off and I replaced the host plant thinking that it was just weak. The radiator is still putting out too much pressure. I have not yet replaced the clutch fan or the thermostat. I was told that it could be the injector cups and I wanted more opinions before I started throwing money at it.
Have you replaced the degas bottle cap ever? i would think that would bleed off pressure before a hose was blown. Is there and sign of oil or fuel in the coolant. Or water or fuel in the oil?
No oil in coolant or coolant in oil. I didnt smell diesel in the coolant or oil. Is there a way to tell other than that?
I would think head gasket.
How fast does it build pressure?
Reactions: ArcticDriver
How is it running other than getting hot? A system not holding proper pressure can cause an overheating issue.
I would replace the thermostat and test again
I would say that the head gasket is out cause thats was was going on with my dads 7.3L but if you wanted to replace the thermostat you can but i highly doubt that that is the problem
Start with the most expensive way to maybe fix it and then work backwards from there.
Buy a new truck????????????????
This problem would be solved and new ones created.
I vote for replacing the degas bottle cap (under $20), and checking the fan clutch, replacing that if necessary.
Or you could go the new truck route like bugman suggests. LOL ;)
He already said was bad. But for some reason also said he still hasn't replaced it......
Sent from my SM-N960U using Tapatalk
1 - 15 of 15 Posts
