I have Pressure In my cooling system when cold now mind you I have a block warmer plugged in to help the truck starting better It goes in through sort of a freeze plug hole. The cooling system Pressurerises allowing coolant to escape throught the over flow tube. Ive replaced the thermostat. also I have taken the hoses off the heater core just to see if coolant would come through them but it barley does. we've replaced the water pump and thermostat to see if that was the prolbem also we have blown through the radiator and lines and had coolant coming out the oppisite side of which we were blowing. Could a plugged heater core cause the truck to build pressure?
And does water flow through it when the engine is started cold or just when its warmed up?
Also before when I started it up after the block warmer beeing plugged in all night I had Instant Heat not hot but warm not I dont have heat only some times when Im Step on the accelerator or let off but if im at a steady speed it goes away
