Sorry about all the mix up,I have not found what the problem is with my 99 7.3.I will repost,week ago I drove to the store got back ih crank but no start.I towed it home replaced irp,icp,fuel pump,gp relay,about a year ago I installed new injectors,glow plugs,harness, all was fine till a week ago.Cranks no start,got it started lots of white smoke runs bad no sel light seems to idle ok but give it fuel runs bad and smokes.Also replaced cps.Any ideas
I would test my GP system again including the new Relay and the GPs.
What brand Relay was it you purchased?
BAD ADVICE GIVEN BY ME
DENNY
Plug it in for 4 hours if it starts fine the glow plug system is not the problem. You need to have the codes pulled.
DENNY
Did you say that correctly?
OOOOOPs:shock::shock::bash::bash: Major brain fart disregard my post!! Thanks Arctic.
DENNY
Its good advice to the OP to plug it in and if it starts OK then it points to a GP issue.
