On a couple of occasions, I've experienced a momentary hesitation or rough acceleration as the turbo begins spooling up. As this is happening I also see a puff of white smoke out the exhaust but as it clears up on acceleration it turns dark. This has happened after the engine is warm and I have shutdown and restarted the engine. If I let it sit for a couple of hours and then restart, the hesitation and rough acceleration goes away and everything seems normal.
Any ideas as to what is causing this intermittent problem? /ubbthreads/images/graemlins/shrug.gif
Thanks for any input.
Deucer
Sounds to me like the EGR valve is sticking. Bring her in to the shop and have them check it out. While its there get the new ebp sensor and have them run the vin for the wire chaff recall that came out today. mine did the same thing. stuck egr valve. /ubbthreads/images/graemlins/smirk.gif
Thanks captpn, that's what I was thinking (EGR). I appreciate the feedback.
deucer
Does the wire chafe problem/recall pertain to the 05's as well?
· Banned
Have the unit flashed to the latest calibration at the same time. There are changes to the EGR and injector strategies.
