I have two early '99 PowerStroke pickups.
#1 F250 Auto Transmission, 236xxx miles, no SES light or codes
#2 F350 Manual Transmission 130xxx miles, no SES light or codes
Both trucks have Ford AIS Intake, MBRP 4" Turbo back Exhaust with stock Catalytic Converters installed (required for emission test).
#2 has a PHP chip, but set on Stock and the readings haven't changed since before I added the chip.
Where I live requires annual emission checks. Every year, the trucks are +/- 1% of the previous year's results. They both pass easily, but for some reason, #1 has always been super clean and #2 always reads higher on its opacity results in spite of having about 1/2 the miles.
Here are this year's results:
#1 #2 (#*@! Can't seem to create columns. #1 is first column, #2 is second)
60 MPH 01% 12%
50 MPH 01% 16%
40 MPH 03% 19%
What could I check to find what is causing the higher emissions from my F350?
Thanks for your thoughts.
Maybe #2 isn't broken in yet. :lookaround:
It could be something like a fuel pressure issue, ICP issue, maybe a difference in tuning. It would be interesting to do some testing, but I doubt the guy at the inspection station is going to let you play with his machinery while you change parameters.
Boost leak?
throw some cleaner in, maybe you the fuel system on the one truck is gummed up if it doesnt get driven as much as the other.
ya you could have a slight boost leak too
