bought a mechanical autometer trans temp gauge.
I know i dont need the temp gauge for a 6 speed but i wanted to fill my gauge pod......and these questions may be elementary but here it goes.
couple question, i tried to insert the provide 1/2 inch thread adapter to which the sending unit screws to and it seem like it was loose.....was that the right threading? if not do i need an adapter?
the port was the plug which to need (i think) a 1/2 inch breaker bar.
if anybody has pictures of their installation i'd appreciate it, i have searched the forums and can only find auto info.
someone makes an adapter for the drain plug witch will accept the sending
unit for the gauge...ya ya i know im a lot of help with out the name or
company that sells it.
but i have seen it recently
or you could do what myself & some buddies did, we all welded bungs in the
pto cover plate & installed them there. just remember if you go that rout to weld the bung so its in oil when you install the cover back on.
thanks. im not trying to weld that thing and all that involved, but thats great to know the adapter is available. i appreciate the reply.
next two questions....
1. until i get time to cruise the site for the company which sells the adapter, does anybody know who it is?
2. even the the temp isnt that important to a light hauler with a 6'er, will i get a decent reading?
I purchased the adapter (5 years ago) from Diesel Power Products. I don't think they're a supporting vendor any longer. You can do a search and find their web site. It cost about $30, including shipping, and took just a few minutes to install. Just ask them if they still have the Manual Transmission temp plug for a Ford 6-speed.
I get good readings on mine, but keep in mind that the temp reading start at 100°. In real cold weather I might not get up to that.
i have a digital gauge so i get readings from 0 to whatever
i think the highest ive been was 244 deg.
