My clutch blew up last week, so have the tranny out, and while I was fixing the clutch, I figured I'd replace the rear main seal as well, because it was drooling enough to wet the pan near the starter motor. It's NOT coming from the valley, although the EBP actuator seal is leaking a bit (not enough to drip).
Anyway, I was going to stop by the International place on Friday to get a new RMS, but had too many other things going to be able to get there. Ford was open today, so I went there to get a seal, and the parts guy brings out PN F4AZ-6701-A which he said was the newest part #, having superseded one that ends with AA. When I saw it I balked, because everything I've read about says the RMS comes with a wear ring, but this one was a standard rubber lip seal without a wear ring.
So my question is, have any of you guys replaced a RMS with that type, or have you always used the one with the wear ring? Is the standard type seal superior to the originals or the seal/wear ring package?
on edit: the # on my original seal is 1823404C1, but that doesn't cross over to any Ford #, and it's a metal ring seal while the new Ford one is rubber coated on the outer edge and contains no numbers at all.
