I have my E4OD disassembled. I made the tools needed for compressing the first piston spring and slide hammers for the pump. My question is do I really need the pump banding clamp and the other tools? Is it possible to just line up the holes and torque the bolts down? I mean it can only go on one way right?
Dan
Whats does banding it together actually do?
Lines up the two halves that form the housing for the gerotor pump inside.
I didn't use a banding tool or hose clamps. I used a 6 inch straight edge and went around the outer surface tapping the cover back and forth till it was perfect.
