Ive been reading alot about making w85 lately and decided to give it a try. Today I went and picked up 2 - 55 gal barels, one with an open top and one with a closed top. I also picked up a few whole house filters and all the fittings I thought I was gonna need. I just re-read the "wmo how to" thread and now see it says to use string wound filters. I was going to use the ones that go with the whole house filters but now Im wondering if those won't work? They look like there made of styrofoam or something.
Also let me know what you think of this plan for filtering. I was going to weld a 3/4" nipple near the bottom of the open drum. I would put a valve on the end, then a 30 micron filter, then a hose which would lead to the closed drum. The closed drum would be placed on its side, and I would atach a nipple and valve to the small hole, this would lead to a 5 micron filter and the pump with a hose atached. My plan is to dump the used oil into the large drum and add my 15% gas, then mix it up with a wooden paddle. I would then allow it to sit for a few days and then gravity drain it into the closed barrel. Then I could use the hose off the pump to go back into the top of the barrel and run the pump to circulate it for a while. After circulating for a while, I would take the hose off the top of the barrel and use it to pump into my truck. Does this sound good?
