The EBPV(Exhaust Back Pressure Valve) is the butterfly valve on the down pipe side of the turbo exhuast housing. It is operated by oil pressure, so with the motor shut-off it should be open. The PCM opens/closes it to help warm the enigne. I have never heard of someone wiring it open, but you could unplug the connector at the base of the pedestal to disable it.
Is the red hose you are talking about plugged into a little cannister that is bolted to the compressor housing? If so it is for the waste gate, which is controlled by boost pressure not vacuum. This I have heard of people wiring closed, it should be closed when the motor is off and until you reach a certain level of boost. Disconnecting the red line should keep the waste gate closed.
To me, neither one of these sound like your problem. I have unhooked my wastegate, and I have had a sticky EBPV before and neither one caused a lurching or shuddering. Do you notice high egts and/or low boost when it happens? If you hold the light throttle does it continue to do it as you pick up speed? If you give it more throttle does it go away? Does it go away after it is up to temperature? It doesn't happen to do it at a certain speed does it(35-40mph)?
