I was trying to remove the check ball with some small picks, and now it's stuck in the front cover side passage. It spins frely but I cant seem to get it out. I've tried using compressed air on the standup pipe but still no luck. It way to do this, besides removing the front cover?
Magnet?
DENNY
Can you see the ball? Here's how we get "foreign objects" out of kids ears sometimes - clean the surface of the foreign body. We use alcohol or acetone, but brake cleaner would work for you. Make sure and let it dry. Put a drop of gel superglue on the wood end of a cotton tip applicator (a long wood stem q-tip) and gently hold against the ball - hold it still and count to 100 real slow. Gently pull the object out. This is especially exciting on a hyperactive two year old, so you should have no problem doing it on a 7.3
Pulling the cover isn't a desirable method - the engine has to come out of the truck to do this because the oil pan has to come off to get the oil pickup tube off.
· Administrator
How much air pressure did you use? I would think that a good blast of air would get it out of the side passage and back where you can grab it with a magnet. Try both a magnet right at the ball location and air at the same time down the standpipe.
I can imagine getting that ball out with picks is like trying to eat peas with a knife. :winking:
