I have a 2011 KR 6.7 with the rapid heat option . Anyone know where the fuse is for this? I looked in the book but it doesn't show it listed. I'm having A/C problems and would like to take the fuse out for the rapid heat to eliminate that as a possible cause of my A/C problem.
cwtex04
Sent from my iPhone using Autoguide
There is a 125 amp mega fuse beside the passenger battery for the element, I believe that it is the last one on the block closest to the cab? An 10 amp fuse (F37) in the BCM for the heater control module (AHCM). A signal on the CAN BUS tells the heater to come on.
Ok thanks I will take a look and see of I can find it.
cwtex04
