So I have a 1999.5 F250 7.3. About 2 weeks ago I noticed that when I was driving it and used the turn signals, the driver side is fine but the right or passenger side blinker comes on but does not blink. Just solid on. Now, the emergency flashers work. Inside and out. Ok so I switched out the flasher relay behind the dash. Went through the ash tray. No improvement. So I bought and replaced the multi function switch (with the turn signals and high beams I think?) Anyway, still no improvement. Still on- no flash.
Side note: around the same time as the flasher issue arose, I decided to remove the old set of fog lights that have not worked in ages. I found that the way that they were powered was to attach them with a pinch connection to one of the headlight wires--on the same side as my current issue. I removed the pinch connection and taped it up. Might that be related? Tyia!
