2010 F350 Factory rear camera question. Where does the factory wiring connect to the camera at the back? Truck is/was set up from the factory with this option. Finally figured out my rear view mirror does not work because the Sync microphone will not pick up, and the compass on the dash does not register. Have a new "used" mirror on the way. My tailgate handle has the hole for the camera, but the camera is gone. And I do not see any wires going into the tailgate. All the fuses are in place for the rear camera, so someone removed it at some point. Want to get it back in operation with a replacement camera.
Just need to know where to look on the back end for a connection point. I see an oblong hole in the end of the truck bed, and a larger square hole in the bottom of the tailgate, and they are pretty close to each other. I'm assuming this is where wiring would route? Have no idea what to look for under the truck though.
