The inside rear door panels on my EX are coming loose from the fiberglass. They use a plastic push pin type mount that seems to be a one time use kind of thing. I pulled one off and it seems to be ok. The female part that would be mounted on the inside of the door has pulled out of the door and is attached to the male barbed part. It mounts in a slot on the inside of the fiberglass door. I had the dealer order me a few new ones so we can see if there is a difference. Any ideas?
These are the clips i used to fix my rear door panel.
Ford Door Lower Trim Panel Clips W704958-S300
Great. Thanks for the info. I will look it up. I tried the original replacement ones that Ford ordered in. They did not work. It seems like the hole is stripped out in the fiberglass door.
Now that I took a minute to look it up, that is the same clip I got from the dealer. I am going to have to figure something else out.
