Is there a 4 between the L and 10?
That would indicate 4.10 gears with limited slip.
If you get the door jam sticker axle code you can find the ratio with that as well.
I believe all the F250-350's from some time in the 80's till now have used a Sterling (Ford) 10.25" rearend. Our PSD's either came with 3.54 or 4.10 gears unless superduty (F450).
