Hey Matt,
Where in Michigan are you located, if you don't mind my asking? I'm just south of Jackson and have almost exactly the same truck as you (see signature), minus the mods, with the same problem with the leaky differential. I noticed oil on the pig soon after I bought it and now I have a puddle on my garage floor. I checked the level and ended up putting a quart in it. :shocked: :worried: I don't drive mine much and if it will hold out, would like to get this fixed come fall or by the time snow flies, anyway.
On a side note, you may want to check your vent to make sure its not plugged, building pressure and blowing out your seals.
Mike
