1 - 10 of 10 Posts
I have a 2000 Ex and my rear view mirror started leaking this chromatic fluid. Does anybody know where to buy an exact replacement or a place that repairs them. Its a Donnelly 011530 auto dimming mirror with a 3wire connector. ...Thanks
Mine has not been working and just started leaking, too. I just found one for a 2008-2009 on ebay that isn't too expensive but I'm not sure how much of a pain it would be to install. This mirror has a connector on the back. I don't think the one on my truck has a connector. If there is room under the roof panel to modify the connection or if a clean connection can be made in plain view behind the mirror it might be ok.
Mine has the same problem but I've kinda ignore it. This thread is fueling my need to fix it....
Same here....My mirror is leaking....only thing is I don't drive very much at night
so the photochromatic doesn't really help me that much....
I'd still like to fix it....
I checked Tousley's and they cost a good penny.....like couple hundred bucks...
Not sure it's worth it for that cost
I have limo tint on my rear window. So this auto-dim mirror has never been needed. Mine isn't leaking, but the fluid is clearly NOT where it is supposed to be. The bottom half of my mirror is a different color.
Is there anything else electronic associated with that mirror? If I simply replace it with a non-electric mirror and tape off and hide the connector in the headliner, will that affect anything?
Mine wasn't working, am going to cut wires and put a "normal" mirror in. I've already put a wider angle clip on over it I picked up at an autoparts store. Just a little wider but curved and I can see both blind spots at rear wheels. Really missed having it (had one on last truck) so I cut into the plastic on this mirror so I could clip one on. Stock mirrors view sucks imo...
1 - 10 of 10 Posts
