Ok, see what you guys think of my ideal setup and recommend an amp to me.
Kenwood HU, Nice one with 3 preamp outs, MP3 support, aux input etc, remote etc. Probably 50 watts x 4 or something.
Infinity Kappa Components in the front doors. 2-85w RMS - 255w Peak power. Also, tweeters mounted on A or B pillar, Sail Panel or Door.
Some cheaper Rockford or Kenwood etc components in the back.
(2) JL Audio W1 or W3 subs behind back seat. May add one or two more subs later. Not sure on the power handling.
My buddy has a killer system in his Escalade and uses Rockford amps. I really like the feature they have that allows you to have a BASS know. It basically connects a variable switch via LAN cable to the amps to allow you to control BASS output.
I don't have to have that feature as I have a Kenwood EQ that I will probably be using anyway.
So fire away, what amps have you guys used and had good/bad experience with? I want a good middle of the road setup. I can't spend $500 on it, but will pay more not to get junk.
Oh yeah, can I run the components and subs on 1 amp? 4-channel?
Thanks.
Thanks.
