I am looking at regearing (replacing complete axles) my truck from 3.73:1 to 4.88:1 and wondering if any transmission programming will be necessary to make it run and drive right. I know the speedo will be off but does anyone know if there will be problems with shifting?
'05 SD 6.0 Torque Shift, 90,000 on the clock and most hauling heavy
Thanx
Read more: http://907diesel.net/thread/110/regear-05-sd#ixzz49EWwC6C5
I pull a heavy toy hauler and I have not experience any shifting problems.
No programming needed.
If you keep close to stock tire I wouldn't go 4:88. 4:10 or 4:56 will be plenty of power. I have 4:88 but it only to compensate for the 37" tire
Thanx.
The toyhauler is the lightest load we haul. Here loaded for work tomorrow
I'm looking at a set of low mileage F550 axles...
I support, like I said, no programming needed for changing gear ratio.
I charged mine out to 4:56's and haul a 18k+ toy hauler, seems to do fine, I did it to help the tranny mostly.
