I'm trying to remove my old tranny cooling line but don't have enough room between the engine and Frame cross member. I could cut the line to get it out, but then I'd have the same problem to install the new line.
Has anyone done this before? Please help!
Thanks! I'll try and post pics of the issue shortly.
Auto or manual? In my manual, it was definitely tight, but a stubby wrench did the trick. Are you replacing the lines? If you are, cutting them might make it easier, as it's always easier to tighten than to break free.
