I lost the left wheel bearing on my truck and when it went it took out the axle shaft as well. The right hub is an original hub so it might as well be replaced too. It is going to run about $1000 - $1200 to repair the truck with stock parts. Do I stick with the stock ESOF or spend the cash on the Dynatrac? The truck has stock tire size and is mainly used to tow a 6500 lbs cargo trailer across the country. My only reason for thinking about the Dynatrac is that the bearing that just went out only lasted about 10,000 miles. It has been slinging grease for a while as it is all over the inside of the wheel. If you had to spend your money which option would you choose. $1000 on stock parts or $2000 on the Dynatrac?
Mark
Mark
